993 Forum 1995-1998
Ontario E-Test - Can you pass with SAI CEL?
Old 12-17-2011 | 10:46 AM
initial's Avatar
initial
Default Ontario E-Test - Can you pass with SAI CEL?
I only ever considered purchasing a 95 993 due to the emission issues I had read about at the time. Now that I have been sponging up Rennlist 993 knowledge on a daily basis since September, I'm thinking I might of made a mistake and lost out on some potential low RPM torque and additional HP.
I recently e-tested an S60 Volvo in Ottawa, Ontario with a CEL. I passed, but the CEL was due to a minor emissions leak.
Does anyone know if a SAI activated CEL cause you to fail an Ontario E-Test?
-Initial
95 993 Carrera 4
89 911 Carrera
Old 12-17-2011 | 12:03 PM
MDamen's Avatar
MDamen
They check for a cel prior to running the test, but the presence of a cel doesn't fail you. They run a tail pipe test on a dynamometer. The impact of the cel on emissions is so low it probably would not show up in a dynamometer test.
Old 12-17-2011 | 12:13 PM
firesm's Avatar
firesm
I would say based on this quote from the gov literature the answer is no :
If the Malfunction Indicator Light (MIL), also
known as the “Check Engine’’ light, on the
dashboard remains illuminated in 1998 and newer
model year vehicles, the owners will be advised
that it may indicate a malfunction of the vehicle
emissions system.
It was taken from this brochure: http://www.ontla.on.ca/library/repos...002/291809.pdf
Best thing to do would be to call a couple of test facilities and ask them.
And btw, you're not missing out on any great power boost - really.
Old 12-17-2011 | 02:00 PM
boman993's Avatar
boman993
Aren't vehicles 15 years or older E-test exempt in Ontario?
Old 12-17-2011 | 03:32 PM
firesm's Avatar
firesm
Good one +10 years
Vehicles of the 1987 model year and older
Old 12-18-2011 | 09:59 AM
initial's Avatar
initial
I always read it to be 1988 and up, thus making the purchase of an 87 911 G50 a wise choice, but I may be mistaken. I have an 89 and do need the e-tests.
Another concern I had when I made de decision to purchase a 95, was the premature valve guide wear on Vram cars. I never did quite understand if the 95 suffers from the same problem.
Old 12-18-2011 | 04:17 PM
firesm's Avatar
firesm
My quote above that states 1987 is directly from the brochure that I posted a link to above. I believe that it's 25 years or older that don't need to be tested, so 2012-1987= 25.
Yes, they do as well - except for the guards red ones
Quick Reply: Ontario E-Test - Can you pass with SAI CEL?
