993 Forum 1995-1998
Door stop pops
Old Dec 14, 2011 | 11:11 PM
jberilla's Avatar
jberilla
Default Door stop pops
When opening and closing my drivers side door on my 1997 993, the 2 places where the door "stops" cause a popping sound from within the door. I'm trying to figure out the fix for this but can't find anything here on the site. Any advice would be apprceiated. Thank you. Happy Holidays.
Old Dec 14, 2011 | 11:20 PM
Spidey 993
Guest
Posts: n/a
That sounds like what they call the "door check strap detent assembly". Depending on if the latch brakes inside the door panel or the latch itself would determine if it's a simple latch repair or a weld job.
It's important because it keeps your door from flinging wide open.
Check p-car.com under the DIY section and "repair items" for additional info.
Old Dec 15, 2011 | 12:00 AM
MDamen's Avatar
MDamen
It is usually the metal where the door strap connects to the body. Do a search and you can read about the fixes.
Old Dec 15, 2011 | 12:34 AM
jberilla's Avatar
jberilla
Thanks guys! I will definitely check p-car.
Old Dec 15, 2011 | 01:39 AM
user 70801213's Avatar
user 70801213
these do wear out and are simple to replace, the attachment point on the car body typically breaks off.
Old Dec 15, 2011 | 05:24 AM
Rialas's Avatar
Rialas
Hopefully it's the door check strap part that connects to the pillar.
If its within the door, you may end up needing to replace the door. Hopefully that's not the case here.
I do find it hard to believe that these guys were unable to repair the door as I had never heard of this issue before until this post.
http://www.911uk.com/viewtopic.php?t=68661
Old Dec 15, 2011 | 07:54 AM
ble2011's Avatar
ble2011
Very common problem on the 993's. My drivers door stop tab was pulled out from the spot welds (on the inside of the door pillar) when purchased. I drove it for a year that way. I was always careful to not open the door all the way, but never really caused a problem other than the noise opening and closing the door. I had the drivers door and passengers door stop mounting tabs welded to the door pillar from the outside. Was not too expensive and the welds were top notch. It was welded, then ground down to a smooth "fillet" and repainted that now looks like it came from the factory that way. I'm still very cautious about not opening the door all the way though.
Old Dec 24, 2011 | 06:40 PM
jberilla's Avatar
jberilla
Thanks for the information everybody. It's definitely the door check strap and I found the DIY on P-car, so I now know what my next project is..
Old Dec 25, 2011 | 02:35 AM
Marc Shaw's Avatar
Marc Shaw
Super Duper Moderator
There is also a link for it here.
Marc
