Front end squeak when i go over a speed bump
I get a front end squeak when i go over a speed bump. The '96 Carrera 2 sat for many years with no use and had 31,000 miles on it when I got it 18 months ago. It now has 36,000 miles. Runs flawlessly except for this annoying squeak. Is this is a simple 'lube' job, or ? Thanks!
Had the same problem. You need grease in the front sway bar bushings, nothing to worry about. Its a real stinky kind of grease, don't remember what kind. It wont hurt if you don't fix it, but it is annoying, so I had it taken care of. You need to loosen the sway bar and lather the bushings real good.
Hope this helps.
Hope this helps.
