993 Forum 1995-1998
993 tiptronic problems
Old Nov 14, 2011 | 07:01 PM
Per Gunnar's Avatar
Per Gunnar
7th Gear
Smile 993 tiptronic problems
Have problem a problem with my tiptronic gear.
It doesent come out of P(park) when I turn the ignition on and start the engine.
As soon as I stopp engine and turn the key on step back (ignition stillon) the gearstick runs free between all gears.
It sounds like its an eletrical issue or a reley under the gear stick cover that doesent engage properly. If I turn on and off the ignition several times, the gearstick suddenly work proper.
Anyone tha have had these problems? or do anyone have an idea how to fix this?
Old Nov 14, 2011 | 08:47 PM
ga993's Avatar
ga993
Had this happen to me. My brake signal was bad. IIRC, it is an inexpensive part with not much labor.
Old Nov 16, 2011 | 02:40 PM
Per Gunnar's Avatar
Per Gunnar
7th Gear
Thanks, do you have the Porsche 993 partnumber for this brake signal part?
Old Nov 16, 2011 | 04:45 PM
ga993's Avatar
ga993
Gunnar, sorry, I have sold my tip and all of my records went w/ the car. My mechanic ordered the part.
Old Nov 16, 2011 | 04:58 PM
mjsporsche's Avatar
mjsporsche
Hi Brandon.
And did you pull the trigger on a PDK 997?
Hope all is well in Atlanta.
Mark
Old Nov 16, 2011 | 07:57 PM
ga993's Avatar
ga993
Originally Posted by mjsporsche
Hi Brandon.
Mark
Hi Mark,
No 997 yet, but the hunt is half the fun. The IMS Guardian from Jake Raby/Flat 6 Innovations has me reconsidering 997.1s.
Stay warm up in NY!
b
Old Nov 17, 2011 | 12:54 AM
1pcarnut's Avatar
1pcarnut
Check to see if your brake light switch is properly adjusted. Simplest way is to see if your brake lights come on when you depress the pedal. I believe the solenoid that releases the shift lever feeds of the brake light switch.
7 Porsche Models That Have Aged Like Fine Wine
Slideshow: Some Porsches have become icons with age, proving that great design doesn't follow trends or expiration dates.
By Verdad Gallardo | 2026-06-16 11:24:30
