Issues after battery disconnect?
I have had the battery disconnected for a couple weeks while the engine was out. Are there any potential issues after I reconnect? Aside from the obvious clock and radio.
Location: Lat: 47 Deg 26.848N Lon: 122 Deg 21.341W Seattle
The car will run a little funny and may stall at stops until the ECU relearns all the parameters. It takes 20 minutes and several shut offs and restarts to complete the cycle.
Good Luck!
Good Luck!
Sometimes a high idle, around 1k. Kept blipping the throttle thinking it was hanging up. As others said, back to normal in a day, depending on your driving amount.
