lug nuts ok for my 996 twist?
I am pretty sure I am ok. I just did a search on RL, but I just want to make sure before I go ahead with this. Tomorrow I will be putting on my 996 twists and I just want to makes sure that the 993 lug nuts are OK. I heard the 996 used lug bolts so I just want to confirm that I am still OK to use the 993 lug nuts. I went from the 993 twists 10 inch rears to 11 inch rears so hopefully that won't be a problem either? I have a torque wrench and I will torque to 96 ft/lbs. Thanks again guys!
They will work fine. I have done the same with no problems at all. You will notice the difference in wheel weight if you are installing the 996 turbo hollows. Enjoy the new look of more meat on the rear!
Yes I am installing the Hollows, thanks again for the confirmation. Your car looks great, I love Glacier white!!
