My rear tires are wearing on the inside. I just street drive. Camber -1.3 and toe total 3/16, with 3/32 per side. I'm raising the car up to row sport -10. Any suggestions on more even tire wear?
Less camber and toe, but probably can't get less than -1.3 camber on the rear at that height. I rotate the rear tires when there is more than a 2 or 3 32nds difference in tread depth from inside to outside.
Thanks guys. k-toe/alignment was set by a reputable shop. According to their report I'm within the specs of -1.4 to -.9 camber and 3/32 to 1/4 toe. I wasn't sure if the wear is "normal" with a lowered car. It make sense to take out some camber if possible, I wasn't sure what the toe will do.
What is your current ride height? It varies from car to car but, assuming that you're somewhere in the middle of the RS range, -1.3 degrees on the rear is probably about the least camber that can be achieved without camber plates. I'm at about RS +8 (ROW Sport -12) and can't get less than -1.5 degrees on the rear.
