Just received an OBD interface from ToreB. Great to be able to reset all error codes on ccu which I had caused. I can now test the components without manual intervention.
Still kicks up the rear blower errors though after fitting Fabspeed bypass and I've done the resistor trick and front blowers at half speed. It's getting cold here now so I'll probably stick the blower back on.
OBD on ebay or Tore.Bergvill.com
