Alex,Thanks for the info.Now I can fix both the goldenrod and the intolerable noise my Hargett shifter ,for the 77' with a 915,makes in third gear.
much confusion here... And mixing of products and terms.
any joint used in place of the standard 993 floppy rubber joint will increase NVH.
that's the price we pay for improved shift feel! it isn't much of an increase in NVH
the golden rod is the same concept as the Porsche RS shift rod, same NVH
Originally Posted by IXLR8
had the same problem with his FD SSK which the last I heard was being sorted out. There is a reason why I prefer to make my own stuff...it ends up being exactly what I want.
you are confusing a SSK with the RS style shift rod, aka Golden Rod.
these are two different things.
and yes, that customer was taken care of long ago...
by the way, Porsche uses "crude U-joint" in their RS shift rod...
Alex ,no noise from the FD rod just the Hargett shifter.Mark suggested to wrap it with a pice of garden hose and zip tie it to the joint.That did not work.Thanks again.
