993 Forum 1995-1998
OE Rotor replacement -help!
Old Oct 20, 2011 | 01:59 PM
Coop's Avatar
Coop
Default OE Rotor replacement -help!
Any one using the Sebro rotors and Textar pads? Any leads would be appreciated.
Old Oct 20, 2011 | 04:24 PM
MDamen's Avatar
MDamen
I went with Porsche rotors and Textar pads. Consensus seems to be to pay the extra for the Porsche rotors. I got mine from FD Motorsports.
Old Oct 20, 2011 | 09:05 PM
e9stibi's Avatar
e9stibi
+2. I will do the job tomorrow: OEM rotors from Sunset and Textar pads from Pelican.
Old Oct 20, 2011 | 10:04 PM
Ed Hughes's Avatar
Ed Hughes
You gets what you pays for in rotors.
Old Oct 21, 2011 | 08:29 AM
ble2011's Avatar
ble2011
e9stibi - Please update this post (or PM me) after you've installed and run them. I am looking at doing the same thing and would like to know your difficulties (if any) on the replacement and how well the combination (OEM rotors and Textar pads) works for you.
Old Oct 21, 2011 | 11:28 AM
Afrika's Avatar
Afrika
I replaced my pads and rotors this week.
What came out: Porsche rotors, Textar pads
What went in: Sebro rotors rear, Pagid pads
OEM rotors front, Pagid pads
Haven't even tested it yet, will do so this weekend and let you know.
The install was simple as per the Pcar instructions, other than having to cut the front hose tab slots by hand, and battling to remove the rear rotors because the handbrake had very little slack in the mechanism. Took about 4 hours, but I reckon next time round only 2 hours.
Old Oct 21, 2011 | 12:35 PM
Gunter's Avatar
Gunter
New Porsche rotors and Textar pads in the rear; ~10k miles, very nice.
Disabled the pad sensors by soldering the wires together.
Re-used the dampers and shims by carefully prying them off and attaching them with Permatex on the new pads.
Made sure that the pads had room to move in the calipers by filing the steel part a little.
Plan to do the same procedure in front when the time comes.
Old Oct 22, 2011 | 11:26 AM
Afrika's Avatar
Afrika
Tested the brakes today, problem with a right front rotor -the 'OEM' brand. Severe pitting mostly around the edges of the cross drilled holes. But also some pitting nowhere near the holes!?
Left side is OK though.
Other than that, the braking is good, there's no squealing, and the brake dust isn't excessive.
I'll contact the supplier and post their response for you.
http://db.tt/m4HFyWPv
http://db.tt/gykH3g0b
7 Porsche Models That Have Aged Like Fine Wine
Old Oct 22, 2011 | 08:56 PM
e9stibi's Avatar
e9stibi
The job went as planned. It took me about 4 hours total but I took my time, cleaned the calipers and wheels thoroughly and bled the brakes. I even manged to only brake one sensor. I have 2 993 and this combination just works fine. Sunset Porsche OEM rotors are so "cheap", that i do not mess around with other brands. For my DE 993 it is a not brainer: OEM rotors.
Just go to p-car.com and get the instructions for brake change. The torque for the caliper bolts 85 Nm. Just be patient if you have not done it before. It is all easier after you did the first wheel. Most importantly: Stay safe when you jack up the car and always use stands.
I took out the car for a test drive and an idiot in front of me lost a spare wheel that I ran into ... The front bumper is gone and the undercarriage has some damage. Luckily I had the spare wheel in the trunk that stopped the outside impact by giving the trunk more strengths. It still does not look nice and is still a case for my insurance. Houston traffic ...
Old Oct 22, 2011 | 10:35 PM
Renaud Bizet's Avatar
Renaud Bizet
How much are the OEM rotors at Sunset if you don't mind me asking?
Thank You
Old Oct 23, 2011 | 01:04 AM
e9stibi's Avatar
e9stibi
I paid about 540 plus 95 shipping to Texas about 4 weeks ago. Just give them call. Why shouldnI worry about any aftermarket stuff? They are great to deal with.
Old Oct 23, 2011 | 11:16 AM
Opo's Avatar
Opo
e9stibi
Sorry to hear about the accident but yes , Houston traffic is something else! And also watch out for those pieces of 18 wheelers tires in the middle of the freeway
Slideshow: Some Porsches have become icons with age, proving that great design doesn't follow trends or expiration dates.
By Verdad Gallardo | 2026-06-16 13:40:23
