Ruf 18s rubbing?!
Hi guys,
Anyone had any experience with this? I have a set of Ruf 18s with MO30 springs and shocks. The tires are rubbing only on the driver's side front. Everywhere else is fine. Running 225-40-18.
I was running 235-40-18 no rubbing and now this...!![crying](https://rennlist.com/forums/graemlins/bigcry.gif)
Let me know and thanks!
Seared
Inner wheel ....
Looks like the front offset is off. This is the first I have heard about a 225/40/18 rubbing.
Start with adding a 5mm spacer to both front corners.
Some good info, with a similar problem (19") here:
https://rennlist.com/forums/993-turb...l-problem.html
225x40/18 with M030 setup on a 95 cab. No issues. Like others have said, consider H&R concentric spacers---may even boost the appearance.
May even be a mechanical issue--worth checking out.
After having my mechanic check it out, the Rufs have a 10mm difference in offset and spacers are needed up front. Max 7mm. A bit dissapointing, but the wheels are on and I'm happy. Thanks guys for all your feedback.
