I've used it on motorcycle gas tanks. worked well and I don't remember any problems with the paint. but, it was a race bike so I didn't scrutinize the paint much.
Try a hair dryer and a soft plastic scraper to remove most of the grey adhesive residue. Be gentle. When most gone, soak a paper towel with GG and let sit for a few minutes. Then use scraper again. Note that you will probably still be able to see a shadow of the removed script from some angles/in some light, but repeated apps of light body compound, polish and waxing along with light exposure will help make it become more "invisible" over time.
Park in the sun, to warm up the glue. Wurth Citrus Degreaser is also a good product to use. Then, wash, clay, wash, polish, top with your favorite sealant wax.
Or you can use 3M Adhesive Remover which is made for this exact application. Fast working too, but if you already have GG in your garage it looks like the same results can be achieved
^^^^ Yep it's made for removing the gray backing tape on emblems. I will give it a shot on tar. I always used 3M Wax and Grease Remover, but love a dual use product. I have cabinets full of crap. Thanks for the hint.
I've heard that dental floss can be used to remove the script without breaking it. Depending on the color of your car you may find that you have a "ghost" image of the script in your paint.
