993 Forum 1995-1998
No horn?
Old Sep 18, 2011 | 05:18 PM
CalvinC4S's Avatar
CalvinC4S
If the horn honks, the contacts on the horns are fine.
is it hoooooooooooooooooooooooooooo........nk
or honk honk honk honk
Old Sep 18, 2011 | 05:25 PM
bosch's993's Avatar
bosch's993
its a hoooooonnnnkkkkkk, until I turn off the ignition, I meant the part number for the rubber piece (grommet?) that pushes the contacts away from each other until you press the horn.
Old Sep 18, 2011 | 05:28 PM
CalvinC4S's Avatar
CalvinC4S
http://www.porsche.com/usa/accessori...artscatalogue/
Sounds like you have it.
Old Sep 18, 2011 | 05:31 PM
bosch's993's Avatar
bosch's993
I have looked through the catalogue, but can't seem to find the part.
Old Sep 18, 2011 | 05:44 PM
jscott82's Avatar
jscott82
I don’t have actual experience here, but from what I understand you have to order a whole new frame... and if you car is a 95, the frame has been superseded and you need a 96 frame and corresponding airbag.
FWIW here is what you are dealing with.
frame pn=993.347.088.00 (01)
Old Sep 18, 2011 | 05:48 PM
bosch's993's Avatar
bosch's993
Ok, the frame is the part with the Yellow sticker on it, right? My car is a '96, so it should be current.
Old Sep 18, 2011 | 05:58 PM
jscott82's Avatar
jscott82
yup.. thats the dude
Old Sep 19, 2011 | 02:57 AM
bosch's993's Avatar
bosch's993
Default All Fixed!!
Ok, so there are the 4 nuts/screws that cover the grommets. The grommets were warped and had no spring left in them, causing constant contact. There was another thread about putting some 3/8 inch tubing about 1/8 inch thick. So I figured I would give it a try. At first I put it directly inbetweeners the screw and the frame. No go, same constant honnnnnnnkkk. So I took off the frame completely, and saw that the contact is made behind the frame, where the frame and 4 metal spots on the steering wheel meet. So I placed the hose inbetween the steering wheel and the frame, I could instantly tell that the frame had regained its spring. I screwed the airbag back in, and then reconnected the battery, I twisted the key, and was relieved not to hear a honnnnnnkk. I was syched to find out that the horn worked great, and will probably hold up better then the original design, as the original design was obviously not that great. Well I hope this thread helps anyone in the future with similar problems
Old Sep 19, 2011 | 09:52 AM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
We (and your neighbors) are happy for you!
Old Sep 19, 2011 | 10:59 AM
nile13's Avatar
nile13
I have a related question here. Had a 3-spoke 996 wheel and the horn was working (trust me, you need a horn in Boston). replaced with another 3-spoke wheel and moved the airbag from old to new wheel. Horn still works, but now requires a much, much harder push.
Does something need to be bent up to make an easier contact? Any other ideas?
Old Sep 19, 2011 | 01:49 PM
CalvinC4S's Avatar
CalvinC4S
Originally Posted by nile13
Any other ideas?
Old Sep 19, 2011 | 01:57 PM
jscott82's Avatar
jscott82
Damn... thats good....
Old Sep 19, 2011 | 03:59 PM
nile13's Avatar
nile13
Tat and cleaning ICV, I know. However, it's easier to just get fat and lay on the horn. Don't need muscles, or whatever this bulldozer-looking gentleman seems to have around his upper torso.
The question about horn remains.
