New wheels - Advan TCIII
#47
#48
The wheel specs are on the first page and I still don't think I have the right size tires on...currently, I am on 235/40/18 front and 285/35/18 rear. I do rub a little in the rear on freeway bumps but I think if I am on 285/30 tires, I should be fine. And yes, the car is NB.
#50
Gorgeous very aggressive looking NB. That car color is very rare too!
I'm thinking you may still get rub with 295/30 but it would look great. Hopefully you can pull it off.
#51
they look like 5 spoke versions of Volks TE37 aka Rays wheels
It's hard to believe that any of the 5x130 fitments on Evasive's site could fit a 993nb
the closest is 9x18ET46 and 11x18ET60 which stick out 18.7mm and 17.70mm more than oe 8 & 10 respectively
inquiring minds want to know
now if they are really 8 & 10 being called 9 & 11 because of mismeasurement then that would make sense
#52
sorry, i thought I had listed the offset...here are the specs:
Front - 18x9 +46mm with 235/40/18
Rear - 18x11 +60mm with 285/35/18
I don't recall the camber settings but when I get home, I'll post that info up as well. I have made zero modification to the body and as I mentioned, the rear does rub a little on high speed dips but nothing major. I think if I switch to 285/30/18, i would not rub at all...but would that work with the 235/40 fronts???
I got the wheels from Evasive Motorsports and believe I am the first one with these on a 993. Anyway, call and ask for Mike and tell him Luke send ya!
