993 Forum 1995-1998
'92 C2 Driver window noise
Old Jul 26, 2011 | 09:47 PM
sjsfiji's Avatar
sjsfiji
Default '92 C2 Driver window noise
Hi All,
I'm new to this forum with my newly acquired '97 993. The problem I'm having is that when the window is at it's closed position while the toggle switch is depressed upwards, it makes a noise as if trying to rise some more. What could be the problem? Window regulator mechanics? Motor? Stop switch (if it exists)? Any help would be appreciated. Thanks in advance...
Regards,
sjsfiji
Old Jul 26, 2011 | 11:42 PM
Cactus's Avatar
Cactus
Noodle Jr.
You may have to pull the door panel to see what's going on in there? Where are you located?
Old Jul 27, 2011 | 02:12 AM
sjsfiji's Avatar
sjsfiji
Yeah I figured I need to open her up. I just thought that maybe someone had the same experience...
The sound is a loud tick tick sound as if the motor teeth is slipping past the regulator teeth since the window glass can no longer travel past it's max when closed.
Is there a travel limit switch in there? Just a thought...
Thanks for the reply CACTUS, I'm located in the SF, CA...
Old Jul 27, 2011 | 02:53 PM
Cactus's Avatar
Cactus
Noodle Jr.
I was going to say stop by but.......
