Rear window rust bubble
I'm doing this now. I'd suggest having the area sand blasted instead of just hand sanding the surface or wire brush. It's very important to get very clean metal - then prime - paint - clearcoat and you are in business. Shouldn't be a big price tag though.
I went through this last fall, both front and rear windscreens. Mine wasn't bad and I am glad I caught it early, it was mostly just surface rust. That being said I didn't even think there was anything in the front window until it was removed for an unrelated replacement. I had them grind and fix both removing all the rust then replaced the rear window as the plastic seal channel was brittle and chipped. In order to fix it right a new rear window is needed. At the same time I had the whole roof, cowl and rear cowl sprayed. Probably went a little overboard but it was probably in the $1.5K range including the rear window.
