993 Forum 1995-1998
flywheel Reference Sensor
Old Jun 23, 2011 | 12:51 PM
Vorsicht's Avatar
Vorsicht
Default flywheel Reference Sensor
Is it possible to adjust the flywheel sensor without dropping the engine? My guess is that it is but will be difficult.
Then, what is the proper way the ensure the 1mm air gap?
When I replaced my clutch I had a hell of a time getting the rubber gasket in place and believe the sensor to be out of range.
Thank you very much for your help!
