New SNELL rating
Hi guys,
Any idea what the new (2011 and on) Nnell rating is? I have a helmet that I think expires for DE this year and would like to replace it. Cheers!
Snell ratings are updated every 5 years, with the helmets being available in the fall timeframe of that year. Most current Snell ratings are Snell 2010, and the next one will be Snell 2015. Snell ratings come as "M" for motorcycle and "SA" for "Special Applications" (these are for cars). My understanding is that there are two fundamental differences between M and SA: SA are Nomex lined, and SA are tested against multiple impacts vs M which is tested against a single impact. It has been a while since I looked into this, so don't take it as gospel, though.
Red is always faster.....
Are you going to be at the Porsche DE on the weekend of the 16th at Mosport? I am trying to rearrange my calendar to be there to help out...
You will have to check with your local PCA Chapter for actual rules on which helmets can be worn at a DE. When I was in Chicago Region motorcycle helmets were not authorized. It should be clearly laid out in the tech inspection sheet.
--Joe
--Joe
The check list says the follow:
Helmet: Snell (SA or M) 2000/2005/2010
so safe to assume my Snell M helmet made in 2003 is kosher?
can anyone recommend a good SA helmet? bang for the buck
You need to make sure it fits you. G-Force seems to be a good bang for the buck, but was shaped very different that my skull. I think Simpson is shaped similarly. I ended up with a Pyrotect (also a good BFTB, made by Bell, I think).
Yea, I got lucky, the SNELL 2000 expires end of this month, my event is on June 25th, phew.
Agree, fitment is a big issue. Took me forever to find a motorcycle helmet that fit my odd shaped noggin.
