What wheels do I have?
Hi,
I have 993 C2 with Turbo look wheels.
Yesterday I did some work with my brakes in the front and I have always wondred if I had the hollow spokes turbo wheels.
these where the numbers i could find on my front wheels 993.362.136.04
the ET was 52 I think.
thank you
thank you
Not hollow spoke according to this:
http://www.944racing.de/wheelweights.php
Could it be .01 instead of .04?
Christian
Christian
Here is what I found on another post about the wheels, offsets, and part numbers….
Part numbers:
Part numbers:
Hollow turbo twist (aka Turbo I)
8 J x 18 H2 52.0 993 362 136 00
10 J x 18 H2 40.0 993 362 140 00
10 J x 18 H2 65.0 993 362 140 01
Solid turbo twist (aka Turbo Look I)
8 J x 18 H2 52.0 993 362 136 01
10 J x 18 H2 40.0 993 362 140 03
10 J x 18 H2 65.0 993 362 140 04
Solid turbo twist (aka Turbo Look I, High Gloss)
8 J x 18 H2 52.0 993 362 136 07/08
10 J x 18 H2 65.0 993 362 140 07/08
Offsets:8 J x 18 H2 52.0 993 362 136 00
The wide body cars use the 40 mm offset on the rear
The narrow body cars use the 65 mm offset on the rear
A wide body car can use the 65 mm offset wheel if you use a 25 mm spacer
Remove that piece of tape.
It looks like you'll find another "0" under there. The part of the number that is visible does not look like part of a "4". It is too rounded at the top and what's visible looks just like the zero next to it.
If it is a zero, then you have the hollow spokes.
I looked around and cannot find any reference to any wheel with the numbers 993 362 136 04
![](https://rennlist.com/forums/attachments/993-forum/540725d1306828618-what-wheels-do-i-have-img_0498.jpg)
