Fuel pump and check valve question.
1995 c2.
Did a search and found no answer.
Some Bosch and Pierburg pumps have an internal check valve depending on model/type.
Does the original OEM fuel pump have an internal check valve or is there an external check valve in the nipple for the banjo fitting?
What pump is usually found in a 993? Bosch?
Any pix available showing the pump in situ?
