993 Forum 1995-1998
OBD Code P1121...questions
Old May 24, 2011 | 09:52 PM
Quadcammer's Avatar
Quadcammer
Default OBD Code P1121...questions
Ladies and Gents, my pos is throwing a p1121 code at me.
From what I've read, this is a bank 1 rear 02 sensor heating circuit code. Can anyone confirm this first off?
Aside from just redoing the connections to the 02 sensors, in the engine bay and making sure the sensors are tight in the exhaust, not much else to do right?
I'm guessing its just going to be an 02 sensor replacement?
thanks in advance for all the help.
Old May 24, 2011 | 10:24 PM
The Brewmeister's Avatar
The Brewmeister
Oxygen Sensor Heater (#1 after Catalytic Converter)
Exactly as stated in "Porsche 993 the Essential Companion" by Adrian Streather.
Old May 24, 2011 | 10:31 PM
Quadcammer's Avatar
Quadcammer
Thanks Alan
Old May 24, 2011 | 10:34 PM
cpdjfd107's Avatar
cpdjfd107
I threw some O2 sensor codes and I asked here, and from responses and reading prior threads I concluded that it was my MAF. The car throws the O2 sensor code because the MAF was not reading correctly or screwing up the air flow and the O2 sensors compensated for the air/fuel mixture past their acceptable limits and hence the CEL from the O2 sensor. I cleaned mine with CRC MAF and it idles and drives much smoother and after clearing the codes I have no new codes in 400+miles.
Old May 24, 2011 | 10:53 PM
Quadcammer's Avatar
Quadcammer
interesting.
The rear 02 sensor is basically just for catalyst efficiency, so I wouldn't think it would derive from the MAF, especially just on one bank.
That said, stranger things have been known to happen and popping out the maf is no biggie so I'll do that for good measure.
A new rear 02 is only $45 though, so I'm not sweating throwing some parts at it.
Old May 24, 2011 | 10:57 PM
The Brewmeister
The book also states that this code is a failure type 3 (Input too low or out of tolerance low).
Old May 25, 2011 | 12:08 AM
Slow Guy's Avatar
Slow Guy
Veteran: Navy
Originally Posted by Quadcammer
interesting.
That sounds like a "universal" part. You'll get to cut/solder the leads from your old sensor to the new one. Personally, I don't solder so well so I buy the OEM sensor w/ the Porsche plug already installed for about $80.
Old May 25, 2011 | 12:29 AM
ilko's Avatar
ilko
Agent Orange
Does it come back after you erase it? Mine had it when I bought it, I erased it and it hasn't come back in 18 months/4500 miles.
+1 on buying a Bosch OEM replacement. But before you do that, see if you can swap the rear O2 sensors and whether the ECU will throw a code on the other side.
Old May 25, 2011 | 10:09 AM
Quadcammer's Avatar
Quadcammer
actually, amazon has a sick deal on the oe fitment unit with the plug
http://www.amazon.com/Bosch-13577-Ox...ies/B000BZEIBG
The code did come back ilko, but yeah probably a good call to swap side to side.
Thanks guys
Old May 25, 2011 | 11:03 AM
Arena993's Avatar
Arena993
Originally Posted by 993BillW
Personally, I don't solder so well .
Amongst a myriad of other things (i.e. oil spillage during filter removal)
Mike
Old May 25, 2011 | 10:50 PM
Quadcammer's Avatar
Quadcammer
Well quick update. Undid the connector, sprayed it with electronics cleaner and pulled the sensor out of the exhaust and just cleaned it with a dry shop towel. Reassembled and no ce light in 30 miles and 4 key cycles...we'll see what happens
Old May 26, 2011 | 03:27 PM
vincer77's Avatar
vincer77
Mike
I see that Bill's tribute to your detail job is gone....
