Ruf Strut Brace install - where can I buy longer studs for the front strut mounts
I am installing a Ruf 964 strut brace on my 1995 993. The 993 strut mount studs are shorter than the 964 studs. I searched past threads and it appears I need 24mm long studs. Can these studs be purchased separate from the entire strut mount assembly?
Thanks.
Thanks.
Seared
I ran into the same issue installing the Perfect Power replica a few years ago. My solution was to install bolts instead of the short studs:
Strut brace install
Andreas
Strut brace install
Andreas
