Radio Code....revisted?
Hi All,
Thanks in advance to anyone who can direct me on this! I've read all the posts in the archives, contacted a P dealer and still no luck.
Problem is the usual: replaced battery and must enter code for radio to work. Have the factory CDR 210.
Verified serial number by pulling out radio.... code matching paperwork was hand written on the side. Called dealer who verified the code matched the serial number.
I am entering the code and then pressing up on the right hand selector (But I have also tried down, the left selector, the S and just waiting, and I've tried holding it down for 2 seconds). I am now well into the dreaded WAIT for 60 minutes after 3 failed attempts.
Any input greatly appreciated.
Thanks for offering to check the serial number and code. I did check it by pulling the unit, confirming the serial and the code with a dealer... and it matches my paper work so I am fairly confident I have the correct code.
I am back in the 60 minute "WAIT". Any other ideas?
Update: I have continued to try every imaginable permutation and called two Porsche dealers to see if there was a 'trick' I was missing. Then called Becker. They confirmed the code was correct and suggested that the radio's ECU must have been corrupted and would require repair or replace. Think I'll get something with iPod compatibility.
I don't recall which button by my mechanic pushed a number button after the uptown before he entered a code. I think it was like the 5 or 6.
The advisor tried and couldn't do it via instructions. Call boardwalk porsche Plano Texas
Is there someone near you that will let you try their removable faceplate before you send it for service?
Worth a shot.
BTW, CR-210 faceplates work w/ the CDR-210 units.
Regards,
Worth a shot.
Regards,
So, to wrap this up. Radio now works!! And to sum up, pulled radio and confirmed serial #, then confirmed code which was written on side of radio and in radio manual with Porsche and Becker. Becker suggested I get it repaired or replaced.... I had given up and was pulled over while on a trip this weekend flipping through my manual looking for something else when out of the manual folder slips a radio code 'card'. The code on this card did not match the other 'correct' code. But I gave it a try and it worked!!!! What the devil?!
