993 Forum 1995-1998
760 mm vs 757 mm alternator belt
Old 05-07-2011, 12:36 PM
Paul902
Paul902's Avatar
Default 760 mm vs 757 mm alternator belt
I'm half way through changing my belts and found my old alternator belt is the 757 mm version, but the new one is the 760 mm version. Can I use it or should I get the 757 mm version?
Old 05-07-2011, 02:01 PM
Steve Weiner-Rennsport Systems
RL Technical Advisor
Steve Weiner-Rennsport Systems's Avatar
The 760mm one is for the Twin-Turbo. Use the 757mm one on the N/A cars.
Old 05-07-2011, 02:09 PM
Paul902
Paul902's Avatar
Thanks, Steve.
Old 05-07-2011, 03:56 PM
Garth S
Garth S's Avatar
Hey Paul,
Two wraps of duct tape around the pulley should take up that 3mm of slack - good to go
Old 05-07-2011, 04:24 PM
IXLR8
IXLR8's Avatar
Paul,
My 993 owner's manual calls for a 9.5 x 760 La.
But what was installed on my 993 before the belt failed last year was a 9.5 x 757 LA, part number: 999 192 372 50.
It was replaced with a 9.5 x 760 LA, part number: 999 192 343 50.
Old 05-07-2011, 04:48 PM
Paul902
Paul902's Avatar
Originally Posted by Garth S
Hey Paul,
I'm fresh out of German duct tape though.
Old 05-07-2011, 04:52 PM
Paul902
Paul902's Avatar
Originally Posted by IXLR8
Paul,
Thanks for the call! Mine is an M64-23, a diy I have printed out calls for the 760 mm for this variant, too. Maybe I should try it, although the dealer put a 757 mm on 9 years ago and it has worked fine. I have two shims in there I could remove if need be...
Old 05-09-2011, 06:18 AM
911PERVY
911PERVY's Avatar
PET shows a 776 for the n/a and a 760 for the turbo...........is PET wrong?
Old 05-09-2011, 09:11 AM
AOW162435
Seared
AOW162435's Avatar
I thought the updated pulley called for a different belt?
Andreas
Old 05-09-2011, 10:36 AM
IXLR8
IXLR8's Avatar
Recent PET (see post #5 above) shows a 760.
A 757 came previously installed with 2 x 0.7 mm shims. The listed 760 that I installed was far too tight with those same shims that I installed a third 0.7 mm shim.
Old 05-09-2011, 10:47 AM
geolab
geolab's Avatar
Old 05-09-2011, 11:14 AM
911PERVY
911PERVY's Avatar
OK, thats a fan belt, the OP was about an alternator belt...........
Old 05-09-2011, 11:44 AM
IXLR8
IXLR8's Avatar
Originally Posted by geolab
I'd expect a new belt to be tight, but here was one longer than the replacement and it needed a third shim...go figure. But it is tensioned correctly now.
Old 05-09-2011, 12:52 PM
cmat
cmat's Avatar
Here's the service bulletin that gives the alternator belt used with the revised pulley:
757mm for Turbo and 760mm for Carrera
File Type: pdf
Old 05-09-2011, 06:07 PM
Paul902
Paul902's Avatar
Thanks, Chuck. I do not have the updated pulley, so it looks conclusive that the 760 mm belt should be correct. As stated, I previously had a 757 mm on there and it worked fine for years, but the 760 mm should be the correct belt for me. I installed it on the weekend, but haven't turned over the engine yet since my engine carrier is currently in the trunk of my A3!
Quick Reply: 760 mm vs 757 mm alternator belt
