Boot cover
I have an OEM windscreen and I thought I would avoid any problems associated with ruining the top when it was used. I noticed some "chaffing" on the outside of the top, so I can only assume that is not true. I bought an aftermarket boot cover. When I looked a the Porsche OEM boot cover from my PET PDF, it has 2 little hooks where the one I bought doesn't. Can someone help me to understand if I need these hooks and where the should be hooked to?
I have the metal clips with the RSD option. The clips fasten to "D" rings. The "D" rings are on the RSD. This keeps the part that tucks behind the seat from flapping around. Obviously it is moot if you have rear seats as the boot cover is held in place from being tucked behind the seat backs.
I did have a 89 Cab where the seat backs folded down. There were "D" rings sewn in to the carpet that were on the seat backs.
Mike
Mike
Thanks for the info. I guess I will not be needing the clips. Now all I need to do is figure out how to install the snaps and some wonderfully engineered "pull snaps" that came with the cover.
