993 Forum 1995-1998
Windscreen "rattle"
Old Apr 29, 2011 | 08:54 PM
simonjjb's Avatar
simonjjb
Default Windscreen "rattle"
I took the car out today and for the first time there is a creaking/ rattle type noise coming from multiple parts of the front windscreen. Has anyone else experienced this? It's fairly constant. Tx
Old Apr 29, 2011 | 09:06 PM
deekay911's Avatar
deekay911
There's a TSB technical service bulletin to fix this - you basically insert a 'rope' around the windscreen seal..search is your friend
Old Apr 29, 2011 | 10:39 PM
skl2's Avatar
skl2
TSB 6420
Part number for the rope: 996 541 903 00
20 bucks at Pelican.
Old Apr 30, 2011 | 10:44 AM
Crimson Nape Racing's Avatar
Crimson Nape Racing
Mine never squeaked until I had the windshield replaced, now I spray some motorcycle chain oil under the seal once a year or so and it works great. I just noticed yesterday that my rear window may be squeaking also. Time to break out the spray! BTW, the stuff also helps the rattle on the rear hatch of our 944.
Old Apr 30, 2011 | 02:48 PM
911PERVY's Avatar
911PERVY
Rope works for a while, I then removed it and now use a liquid grease spray, not heard a squeak for 6 months, loads on this as mentioned, search away......
Old Apr 30, 2011 | 03:45 PM
Ed Hughes's Avatar
Ed Hughes
Mine squeaks going up driveways, but not bad at this point. My rear seal not staying in was the problem, but found a flowable silicone that solves this.
Old Apr 30, 2011 | 06:20 PM
skl2's Avatar
skl2
What liquid sprays are you guys using? Or silicone?
Old Apr 30, 2011 | 06:32 PM
Canyon56's Avatar
Canyon56
I was told by a windshield repair guy to never use chain oils or grease, etc., since it will eventually eat away the rubber seal.
Later on my mechanic also brought it up and said to any such products.
Is this true?
7 Porsche Models That Have Aged Like Fine Wine
Old Apr 30, 2011 | 06:54 PM
goofballdeluxe's Avatar
goofballdeluxe
2 choices:
Either the rope, which if installed properly, will eliminate any rattles.
Or Pedro's Ice Wax, which will solve the problem for several months. Some use a silicon spray, but as mentioned above, I'd prefer the rope as I don't wanna keep spraying lube in there ad nauseum.
The rope may be the easiest DIY one can do. It is super simple and easy, and takes about 20 minutes. I did it many months ago, and have never had a rattle since.
Old Apr 30, 2011 | 11:39 PM
Bob in NY's Avatar
Bob in NY
Originally Posted by skl2
TSB 6420
Thanks for the tip, ordered mine today.
Old May 1, 2011 | 04:25 AM
911PERVY's Avatar
911PERVY
Rattle will be back with the rope! I was told that, and 4 or 6 months later, they were right!
How can grease rot rubber? The seal is only cosmetic anyway
Any the grease stop rust too!!
Old May 1, 2011 | 01:16 PM
V's Avatar
V
There are many threads on this. Another problem with the construction of our windshields (front and rear) is rust. This is because water gets trapped underneath the rubber seal. I once saw a case (I can't seem to remember where I read this) where the rope installed (as recommended in the TSB) actually helped trap water thus leading to rust even faster than without the rope installed. One solution to this is to remove the windshield and then re-install it using Sikaflex or some other type of bond (not silicone) underneath the rubber seal. In this case you are 100% sure that no water will get in there (since the whole grove is filled) and thereby no rust issues. The drawback with this is that it will be a lot of work when it's time to replace the windshield..
Old May 2, 2011 | 11:50 AM
mcipseric's Avatar
mcipseric
strut bar. No squeaks or rattles.
Old May 3, 2011 | 04:49 AM
911PERVY's Avatar
911PERVY
Yep, that helps alot
Slideshow: Some Porsches have become icons with age, proving that great design doesn't follow trends or expiration dates.
By Verdad Gallardo | 2026-06-16 13:40:23
