What's this? Please.
The Porsche 993 Essential Companion explains the system in a couple of pages quite well.
It is a one-way valve allowing air to flow to the ports, but prevents exhaust gases to flow back towards the pump after the DME turns the pump off.
If it hasn't failed, a cleaning is all it needs.
I just cleaned mine last week. It wasn't causing problems but since I had it off, why not. Holding the ISV upright with the ports at the bottom, I used lacquer thinner and a small brush...I can't tell the unit has ever been installed.
![Lightbulb](https://rennlist.com/forums/images/icons/icon3.gif)
Thanks to all. ![bowdown](https://rennlist.com/forums/graemlins/bowdown.gif)
Auxiliary Air Pump filter element seems to be the SAI check valve.
Porsche Warranty & Maintenance booklet on page 36:
48 000 km Service:
Auxiliary air pump: replace filter element.
Why Porsche calls the SAI check valve a filter element only the Gods know.![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
Rücklaufventil would be the correct German name.
48 000 km Service:
