993 Forum 1995-1998
BBS LM - reverse mounting the centers
Old Jun 17, 2014 | 11:51 AM
  #31
0-60Motorsports's Avatar
0-60Motorsports
Originally Posted by MartinC2S
I did this on my C2S and havent had any issues. As long as you use lock-tite and the proper torque you'll be fine.
Cool. What torque spec did you use and blue or red loctite?
Old Jun 22, 2014 | 11:00 AM
  #32
dlee888's Avatar
dlee888
Blue loctite with 19 pounds of torque.
Old Jun 22, 2014 | 02:25 PM
  #33
MartinC2S's Avatar
MartinC2S
Correct!
Old Jun 22, 2014 | 04:27 PM
  #34
SPDR's Avatar
SPDR
Enjoying this thread…looks great Nurburger, LM's rock!
Old Jul 9, 2014 | 03:22 AM
  #35
Frenche90's Avatar
Frenche90
What steps would you take with a gunmetal finish?? Also what size bolts were they? Cheers
Old Nov 4, 2014 | 06:41 PM
  #36
SleepRM3's Avatar
SleepRM3
Default Deleted
Deleted
Old Sep 30, 2016 | 11:03 PM
  #37
_snowbird_'s Avatar
_snowbird_
Old thread - I know...
Nurburgring - you mentioned you were going to clear the lips. Did you?
Needless to say, they look incredible!
Originally Posted by Nurburger
Patrick the Polisher delivered the finished barrels yesterday - another perfect but finicky job... Nice to have him in the area!
Here's how they look with stock BBS paint color on the centers - next step is to media blast them & repaint with a darker gray.
Old Oct 1, 2016 | 12:16 PM
  #38
Basal Skull's Avatar
Basal Skull
ymmv and I don't want to be negative, but fyi, I did this and promoted doing so but found I could not get the reverse mounted wheels to balance very well. It may be that I did not get the wheel centers to be centered properly when reverse mounted (the centers do seem to fit better when put together as intended). At regular speeds it was acceptable but at 120-140+ km/h speeds it was very noticeable and did put the wheels back to regular configuration and used spacers. In regular configuration the wheels balanced no problem.
Old Oct 1, 2016 | 04:41 PM
  #39
Knight's Avatar
Knight
Were you getting vibration?
I had a shop properly reverse mount my LMs (Nubrite) from the beginning, they recommended this was not something you would do at home, I recall something along the lines of the bolt sequence, equipment etc.
So far I've had 2 different set of tires mounted on them, no issues at all to date including speeds much above 140km/hr. I know TripleG had his former set done at Panthers, no complaints too. Maybe something to consider if you want to try again next time.
Old Oct 1, 2016 | 05:56 PM
  #40
Basal Skull
I think you are right, it is more difficult to center the wheel center when reverse mounted, where as when put together the normal way, the lips in the wheel center are made to fit into the barrel without any play. This also means that forces are transmitted more to the bolts when reverse mounted as the wheel center is not directly supported by the wheel barrel. I decided it was easy just to use spacers in the end. I can't use the wheels anyways now due to my brakes, they are sitting looking pretty in my den (and no they are not for sale before someone pm's me and asks) .
Old Oct 1, 2016 | 09:37 PM
  #41
ginch's Avatar
ginch
Ha Ha!!! Damn you I was just going to PM you about the LM's!!
Old Oct 1, 2016 | 10:57 PM
  #42
_snowbird_'s Avatar
_snowbird_
I wouldn't be too concerned about this. There are many 3pc wheels that are set up like reverse-mount LM's. BBS RS's for instance are this way from the factory.
Old Oct 1, 2016 | 11:29 PM
  #43
MartinC2S's Avatar
MartinC2S
I reverse mounted my LM's myself using the diagonal torquing method and haven't had any issues in the 4 years since. No vibrations at any speed that I've had the car at so far.
Old Oct 2, 2016 | 12:08 AM
  #44
Basal Skull
I can't use these (or my 4 other sets of 18" wheels), but have decided to keep them as I may get another car in the future - the LMs are particularly a good keeper as I could use them on a narrow or wide body (with spacers).
Old Mar 11, 2018 | 12:21 PM
  #45
justin993's Avatar
justin993
Anyone have pictures of 18" reverse mount on a narrow body car?
