Is there a 95 wide body?
I don't think the WB should hurt this cars sale. It is not like the old 930 that was usually done half *** due to the swing arm geometry.
This look like seal gray to anyone?
Three owners. 3rd owner (seller) has had it for eight years. Records since 2003. Again, seller seems very responsive and detailed over e-mail.
Interior is dark blue though. Not sure about that color with the grey exterior.
well, collectively we have almost all drooled over cars with flares BOLTED on...haven't we?
If this car presents well, the quality of the work is acceptable, PPI, etc...that's a decent car for that money isn't it?
I agree with CalvinC4S, that color looks very interesting. I thought a subtle purple, lilac in there too.
Rennfax by a local?
Rennfax by a local?
One has to wonder WHY the PO decided to replace the rear end of the car with WB bits. It would be logical if the rear end of the car needed replacement for some reason. Like it went backwards into a wall, for instance.
To each there own.
EDIT: This is not an issue with the 993. If that panel work was done well, this car should be gone in no time.
I love how the seller said that it handles better in corners. What gauge was used to determine that? I'm always amazed by the statements that sellers make. I've owned MANY cars in my 20 years on the road and I'd be lying if I said that I could feel this or that... Sounds like a car salesman to me...
The inner pivot is shorter on a 930 (or late steel RSR) arm, and it gives different anti-dive/squat characteristics. This may or may not be advantageous, depending on the purpose of the chassis. The outer mount, where the spring plate attaches to the torsion tube, is the same.
Maybe it would work for a rsr type duplication. But a late 80's factory wide body look? Looks like a kit car done like this.
Some people, not many, will use a jig to move the inner torsion tube mounts to be able to use the turbo suspension, I like this but it is very very rare.
EDIT: Here is an example of trying to fill a torsion bar car conversion with wheel offset. Not my cup of tea, but many like it.
