Engine Immobilizer
First, I hate this system and find it irritating that about 50% of the time I get into my car, I have to reset the key fob, since the immobilizer has the engine locked out. Porsche must have worked overtime to create this lousy system.
So, is there a way to "permanently immobilize" the engine immobilizer system? Short of doing surgery on the ECU?
Second, is there an "easy" way to retrieve the code number? I have heard that I have to contact the factory direct......or that for a large fee.....the dealer will get the code for me. I'd like to have the code to program two new fobs. And, if the system can be shut off, I suspect you would start with inputting the code into the system.
Any help would be appreciated.
You can get the code from your local Porsche dealer. You can get the remotes from Sunset at a good price.
A reputable Porsche dealer will want to see you, your ID, your title/ownership and your car before handing over the code.
Having owned my 993 for 9 years I am always surprised at the complaints regarding the Immobilizer system. Like any electronic system you sort of have to get in the head of the designers. Mine has been trouble-free, if a bit annoying to use.
I have found that fresh remote batteries annually are a must, plus a key hidden on the car and a spare programmed remote in the glovebox will provide a lot of piece of mind.
Early 95's (mostly basket handle cars) did not have them; they were installed beginning about mid MY 95 production.
Most posters agree it is a major project to immobilize the immobilizer on the 95's that have them.
96 and later cars (OBDII) can be easily modified to delete the immobilizer function, something about flashing the ECU; Steve Weiner and others can do it, not very expensive.
Gordo
Gordo
Excuse my ignorance, but who is Steve Weiner? And, does he have to work on the car to do this or provide instructions? Or, do I ship him the ECU. I told you I was ****! Now you know. And, thanks for the insight.
(There is a very recent thread, near this one, regarding Steve and some problems he is having with his eyes....we all wish him well and hope for a speedy and complete recovery).
Extremely helpful and knowledgeable guy; I've talked with him and emailed, always prompt and accurate advice, knows his stuff.
Others can do the "flash" thing though I don't know who; search through immobilizer thread history.
I think you need to send them your ECU, they do the flash and send it right back.
SWAG cost is around $150....
Gordo
With my luck, I'll lose my key as I am getting out of the car (I don't keep my key on the remote ring) and the lucky guy will find the spare remote in the glove box. Even with my custom disable, I won't risk it.
With 73k miles and mostly very short trips, the ignition key had worn the ignition so much that the car was not able to recognize whether the key was in the ignition.
That somehow let to trouble with the ECU.
Finally had to replace the ignition/steering wheel lock with one ordered from the factory, replace the ECU and the starter switch.
Works like new now but I would rather do without the immobilizer, personally.
Some will simply lock and unlock the car before getting in to deactivate the immobilizers. There has been some concern expressed that this may overuse the locking mechanism.
For me, I simply know that I need to push the button once I've turned the key. No dramas.
I agree with Alex - I'd like not to return to an empty parking space.
Not so with immobilizer. I keep the key on me when I'm skiing. Did a nasty (as in one step from a concussion) heel pick a couple of months ago. Must have landed my hip square on the key. So it takes me 1/2 hour to get the damned car unlocked in the snow a couple of hours later. I dared not remove the key from that point on. (Parked the car in my mom's garage that night.) So, next day I'm up at Thunderhill, and leave the key in the car next to my garage up there while I'm out instructing. Some idiot decides he needs to move my car, then removes the key. Another 1/2 hour to get it going again.
Luckily I was able to pull the thing apart when I got back to the shop and resurrect it to where it seems to be working fine again. It's about the only "feature" of the car I worry about.
The night my friend had his motorcycle stolen was the one and only night he didn't have it secured with a HD chain. Security is only good if it is employed 100% of the time; not 99%.
