60K Service
Ok, so I finally got all the parts to get the 60K service done. I dropped the car off today at the indy to get all work done.
1.) Oil & Filter change
2.) New Spark Plugs & Wires
3.) New air filter, cabin filter, fuel filter
4.) New hood & trunk shocks
5.) brake fluid flush
6.) Inspect all belts and replace if necessary
7.) New lower valve cover gaskets
8.) New distributor caps & rotors
I ordered all the parts from AutoHausAZ, and the total came to just over $800 bucks. Plus I got free shipping! I cant wait until Saturday! It will be like driving a new 993! Now if this weather could just get a little warmer...
![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
Thanks, I just called and spoke to the owner of the shop who said they will take care of it. It completely slipped my mind when I dropped it off. I am also a "gas & oil guy" Anything to do with removal of engine parts, I'm not the best at...
Thats excellent. Over the winter I completed basically everything on your list as well as the lifters which were ticking at start up, . Took it out on the road for the first time last sunday. For about 15 minutes one of my lifters was clacking loudly, but that went away. It now runs great, i notice both a difference in power and smothness. You sould have them clean the ICV as well. Mine was pretty gummed up at 65,000k, and its easy to do. Enjoy
I pretty much did the same list that you have for my 60K. But I also had them change the Distributor belt drive. Man, I'm just looking at my log book this was done 4yrs ago and about 9K miles ago. Wow how time flys.
Ryan the Isv is very easy to clean. I'm not good with repairing vehicles at all and I have done mine 3 times already. I can take it out in 5 minutes clean it for 10 minutes and replace it in another 5. If they are going to charge you a lot to get it cleaned spend the $ in something else and DIY or I can show you. It is not something you need to have done with a 60k service, it is more of a routine cleaning that we should all probably do once or twice a year.
Ryan
how's the clutch pedal working? Any "hard" points in the movement, or "funny squeeking sound's"? Ask your Indy what he thinks about the action of the clutch. At 60K, it might be time for a slave cylinder and hose. The little noise and pedal roughness didn't seem unusual to me, but my mechanic commented immediately about it.
+993 on the distributor belt also.
Hoping to get mine back together this weekend, complete with a couple of "ghetto" temp mods before it hits the body shop.
I imagine you'll find cracks in the oem rubber bisquits. It's a labor intensive job, parts and labor will probably add $500 or so to your bill-depending on the labor rate naturally. As mentioned MANY times on here, Walrod bushings make an enormous difference in the car.
Ryan, if you ever experience wandering, tramlining, slight nervousness in the front end...the bushings will nail it back down.
Waaay up on the to-do list..I'm so ashamed I didn't mention it.
and what about motor mounts too?
Just let me know if you need any more help spending your money, OK? I'm no where as smooth, or good as many members here, but I'm trying to play catch up.
Mines going in on Monday for its 60K service. I'm having everything you are having done plus the distributor drive belt and steering rack boots. Can't wait to get it back on the road. Can not believe how much the dealership wanted to charge for the plug wires!!! Even from Pelican they were a little over $500. Why are they so damn expensive????
ding, ding, ding...how could I forget the front control arm bushings?
![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
