Pros/Cons of Locking Out Kinematic Toe
#76
The stiffer RS bushes can be identified by green paint dots, the 993 rear A arms I have have the stiffer bushes, I assume all the others do to.
#77
The cars i've seen w/ full mono-ball suspension don't seem to have any problems.
I'm trying rubber boots over the monoballs to see if that helps
#78
Bill - Why does the toe link have to be monoball?
I've been thinking about installing the tilt kit, and after this thread, changing out the bushings while I'm at it. Even though my car is 30% track (The other 70% going to and from the track) I am leaning toward the RS style rubber bushings, just because I'm a bit leery of going too far. So the question is the Kinematic bushing: Monoball or RS hard rubber.
Greg H.
Edit: I noticed on all the ads for the aftermarket toe links, they say that there isn't enough adjustment with the factory toe link on a lowered car. My car is pretty low already - maybe I'm runnig too much toe or something else is compromised?
Greg H.
You can't get a car much lower than mine, I never had any issues w/ adjustment w/ the stock links, they just don't hold the wheel as steady as is desirable.
#80
I am surprised that you can run rigid links and monoballs for all five links without something binding up a bit. I am sure if you were to model this up in CAD it would fully constrain the suspension, so something must be "giving" a little bit. We have a Supravision "vector arm" which can pick 3D points out in space and plot them into CAD, but I am pretty sure my company won't let me model my suspension system in their shop . If anyone does end up modelling the system I would appreciate a copy of the files.
#83
So here is my take-away:
At the next alignment:
Do I have this right?
- Measure the suspension height after a good alignment
- Make note of the calibrated adjustment nut position on the rear Kinematic tow setting, left & right.
- Verify and adjust ride height to same as previous alignment;
- Verify the kinematic adjustment nut is in the same position;
- Align as normal w/o need to adjust rear kinematic settings.
#84
#85
BUT, isn't one of the keys here that when you replace the rear suspension with ALL monoballs, you are virtually eliminating bushing deflection and therefore most if not all of the rear wheel toe deflection under load that the KT was designed to compensate for?
So basically, when changing all rear bushings to monoballs, eliminating the KT function results in little or no negative dynamic results.
But, if you were to change the KT bushing to a monoball only, then you would be defeating the KT function yet the rest of the suspension would still deflect, allowing for increased toe-out under load. Not really a good thing.
The KT arm is above and behind the wheel hub. Therefore, any independent load towards the car’s center, causing any flex on an individual inner mounting point, except for a rigid KT arm mounting point, would cause the bottom of the wheel to move in and/or the front of the wheel would move in.
Therefore, toe-out could never occur with a cornering side load or under braking with a rigid KT arm. This also means, it is safe to have an RS bushing for the A-arm rear bushing, while having monoballs in every other rear link location (A-arm front, camber, toe, KT).
Is my explanation valid? And is the above quote incorrect? Credit to Bill Verburg for the pics.
#86
Bump for the question in the previous post.
Basically trying to decide if I can go full monoball kit, like Rennline’s KT, Camber, Toe with RS bushes in trailing leg and outer leading leg. I said “can”, maybe I will also ask, “should” I?
This is for a summer country road blaster with a couple track days.
#87
- up and down movement of the wheel which is determined by the geometry of the arms
-elastic behavior of the rear inner bush on the A-arm, #5 below, the elastic give creates a twist around a virtual axis as the wheel moves up/down, the upper end of the virtual axis is controlled by the outer ends of # 3 & # 4, the lower end by the outer ends of # 1 & # 5, the KT arm #4 when lengthened pushes the upper end of the virtual axis out and forward, this also moves the wheel forward and down(raises ride height), the geometric effect is to reduce caster and decrease camber, the dynamic effect is to speed up the reactions of the rear ie, the rear becomes twitchier, if the KT arm is shortened the opposite occurs , castor increases and camber increases, this slows down the rear reactions as the tire gets closer to the muffler and lowers ride height
Both of the above effects are always going to be present as long as there is any rubber connection. The stiffer the connection, either at # 5 or #4 the more controlled the change in length of the respective arms, this translates to more precise car control, at what ever static settings are chosen. The reduction in KT effect w/ increases bushing stiffness has no effect on the inherent geometric toe change w/ bump/droop
The most precision comes from mono-***** at both ends of at all 5 arms, if any of the ends has reduced give it asymptotically approaches the pure mono-ball state and conversely if any are given increased play w/ softer connections action moves further away from the pure mono-ball state
i've driven all 3
the RS setup would have been totally acceptable for street and track except for the fact that the eccentric adjusters are just not reliable in severe track use
I currently run pure mono-ball f/r and even w// very stiff springs this is perfectly acceptable for the limited street use I give it, w/ good digressive shocks
I would advise locks and booties on all the and an occasional spritz w/ WD-40 under the booties
LimeyBoy (12-02-2022)
#88
Thank you! I’m processing the information as I decide on the rest of the joints. I did order the monoball control arms during the Black Friday sales. For the boots, rather than WD40, I will use LPS-3 corrosion inhibitor. It’s similar, but different to Fluid Film. https://www.itwprobrands.com/product/lps-3
EDIT: Upon doing more research, it appears that bearings lined with PTFE fabric should not be lubricated. The lubrication acts as a holding agent for dirt and other abrasive particles. In one spot (SKF bearings) I read that flushing with a liquid lubricant, even water, would be beneficial. The purpose of the dust boots is to prevent contamination altogether. So, the suggestion to flush with WD40, which is very liquid, rather than a thicker substance like Fluid Film, seems to be the better advice for durability.
EDIT 2: Best to keep them clean by having good sealing boots. If contaminated, use soap and water, and dry them. Attached article with quotes from FK themselves, https://www.chevyhardcore.com/tech-s...e-of-rod-ends/
