Pros/Cons of Locking Out Kinematic Toe
#61
Yup, 30mm increased track each side
#63
Yes, but if you plan to race this car you have a laundry list of parts needed:
EVO uprights, GT2 tie rods, alteration of the lower carriers (some are factory drilled on the earlier cars). Movement of the brake booster if so equiped. Movement of the solid brake lines. Movement of the brake pedal arm. Alteration of the front sway bar drop links. ERP camber plates for max range. I had to run mine in reverse to down to 3.5 deg of camber. Fenders flares to maintain proper offset and scrub radius......... End result is top notch handling and 10inch rims up front. Ironically you can still run small tires on existing rims with improved traction.
#64
Bob993,
Bout got mine track ready finally. Just finishing up rebuilding the brakes and Im off to TWS for my first race weekend and testing. Gonna be interesting for sure. Not sure how much learning curve Im gonna have in this new beast.
Jeff
Jeff
#65
Jeff, start with the front sway middle to middle loose and middle on the rear bar. As you get better with the abrupt turn in, move the front sway to full loose. Experiment with this and look at data to decide on a per track basis. Chris prefers slight understeer at tracks like WG, but Summit Point and Tbolt you want an oversteering monster for the slow speeds. Keep me posted I am sure you gonna love the feel. BTW what camber did you end up with fr and Rr? What front end is on your car now?
#66
I put the EVO 2 front end on and it fits perfect. I spaced my front wheels out 5mm but could have gone a few more. The rear wheels I spaced out 17mm with a hub centric spacer to get as wide of a track as I could. My flairs gave me a lot of room out back. I put the 17 spacer on the front and they fit but would probably have torn up my front flairs. Ill probably settle on 10 to 13 in the end to get the best track. Chris wanted it as wide as I could get it.
Ill check the exact numbers Chris got me but its roughly neg 4 in front and in the neg 3s in the rear. If you PM me your e mail Ill shoot you the allignment sheet he gave me. He set up my suspension for the Yoko slicks. To the naked eye it looks crazy!
I think that is exactly where he has my sways set right now and Im about mid range on my shocks but told me I will probably like it at full stiff once I get use to every thing. I have a full DE day with lots of track time so I plan on making a lot of big changes just to see how all the different settings work and feel.
Ive got a LOT to learn this first weekend as there is sooooo much new from the suspension, tires, wheels , springs and most of all, all my shift points with the new full race tranny. First gear goes almost to 70 mph Basically its a new car.
Ill keep ya posted.
Jeff
Ill keep ya posted.
Jeff
#67
Great thread...what still doesn't make sense to me is that according to the Porsche explanation, links 1,2,3,4 are rigidly mounted and link 5 is elastic, but we've seemed to suggest that 1 is rigidly mounted (the monoball Chris posted pics of) and 2, 3, 4 and 5 are ALL elastic (rubber bushes).
#68
#69
So, 2,3, and 4 are rubber and 5 is somehow different? What technology or design makes 5 elastic? When you got your RS arms, was 5 still different from 2,3, and 4?
#70
RS rubber bushes are even stiffer yet
#72
For a track only car the stock arms w/ all monoballs & solid sides is going to be more than satisfactory.
For a dual use car I'd use the Elephant racing hard rubber bushes except for the toe links which almost have to be monoball w/ locks & solid sides.
the big negative w/ monoballs is durability. I have had to replace them after as little as 1 yr and ~1400 track miles, pretty expensive.
#73
Bill - Why does the toe link have to be monoball?
I've been thinking about installing the tilt kit, and after this thread, changing out the bushings while I'm at it. Even though my car is 30% track (The other 70% going to and from the track) I am leaning toward the RS style rubber bushings, just because I'm a bit leery of going too far. So the question is the Kinematic bushing: Monoball or RS hard rubber.
Greg H.
Edit: I noticed on all the ads for the aftermarket toe links, they say that there isn't enough adjustment with the factory toe link on a lowered car. My car is pretty low already - maybe I'm runnig too much toe or something else is compromised?
Greg H.
#74
But in the RS kit, is 5 softer than 2,3,4? IE did Porsche leave the same kinematic effect in the RS? When you replace with aftermarket rubber bushings you get all the same for 2,3,4,5.
#75
ERP links will give you more control over the geometry of the rear end. To my mind that is going way beyond what most of us are capable of dealing w/.
