Flap in fuel filler neck is gone!
Saturday I went to fill up the 993 and add a can of Seafoam. Got my knife out to open the metal flap in the neck of the fill nozzle (so the Seafoam would go in), and it is not there! I have no idea what happened, but I assume it is in my gas tank. I can't think of any damage it could do, so I am not going to worry about it for know.
Funny. I just noticed the same about my fuel filler neck. Flap isnt visible. . Need to see if it's stuck open. Anyone else experience this or did OP ever find a solution?
“Accept the things I should not fix, have the courage to fix the things I must and have the wisdom to know the difference”
Fuel filler flapper
Mine also was stuck open. Didnt think a flap existed for the whole time I owned this car. It gets stuck when the fuel pump nozzle is jammed into the throat and torqued upward if you rest the fuel pump nozzle in the throat. This could have been the root cause of the fuel smell I could never mitigate from my cabin when I would fill the tank. There is a metal divider down beyond the flap that bends easily upward and prevents the flat from closing. Use a flat head screw driver to bend the divider downwards and the flap will once again reveal itself and close. Do not pry the flap itself. Easiest repair in decades.
Okay... this gas filler flap business. I can't leave well enough alone. Mine is stuck open as well. Is the piece of metal that arcs upward and catches the flap really a divider? I've bent mine down enough to clear the flap bottom edge but there is a curled flange on each side of the "divider" that still catches the sides of the flap allowing it to close only halfway. I cannot figure out how to relieve the curl on the divider to allow clearance.
The "divider" is now bent almost flush with the wall of the filler pipe. It does not divide the opening. Is it supposed to? I'm thinking about whether or not I'll have gas splashing back at the next fill up.
I had the same problem. Learned of this after I bought a new filler neck. Saw that it had a flap and thought they'd added it to the newer design. Then I tried my first fill up with the new neck and was surprised the nozzle would only go in a few inches. Thought the new one was defective because it had a divider right across the diameter. Then I finally looked at my old one and saw that it also had a divider that had been bent over to one side by years of nozzle cramming - and it had a flap that was caught in the open "invisible" position.
deleted double post
So does a filler with the divider bisecting the opening allow the nozzle to go deep enough to remain unattended while filling?
Is it possible to take a picture of an unmolested filler neck? I'm curious as to what needs to be done to free up the flap. I assume the curls on the sides that are hanging up the flap were out of the way at one time. I'm not too keen on over leveraging the damn thing.
Yes, oddly enough, I've had no problems with auto shut off even with the shallow divider. I suspect the divider was added because the neck is plastic and if the nozzle goes in all the way, the weight of the hose would press the tip up against the plastic internal back of the neck and crack it over time.
I'll see if I can get good photos of my old one - which I easily straightened to match the new one.
Huh...my 993 had the same thing. I didn't even realize there was a flap in there until I looked close. Bent the divider back down and the flap snapped back closed.
Thanks rennlist!
Thanks rennlist!
