Help with bodywork-bumper bar..
Attachment 515497
Attachment 515498
I need some help adjusting the bumper bar after asmall accident i had several years ago that i did not realize several years later after i took bumper off. My lower part of bumper looked a little crooked so i wanted to investigate a little further. The bumper was replaced but i guess bodyshop didnt do anything with bumper bar.
there is a small gap in the area that is circled...how do i fix this or push bar back up a little.
Can anyone help with this?
Thanks!
Attachment 515498
Thanks!
Although both answers may sound crude, I am pretty sure that is what a body shop will do if you take it to them.
Remember, no one, and I mean NO ONE will take more care with your car as YOU will.
My son got a crease in the edge of the door on his Mazda 3, I put a bunch of painter's tape over it and started tapping with a hammer. the first few taps were a bit nerve racking, but slowly the crease came out.
It certainly ain't perfect, but it is not noticeable, and it doesn't rub.
I figure I saved a few hundred bucks...bucks I can justify putting into the 993 that the wife can't complain about, especially since she is the one that parked the car next to a pole on that windy day and put the crease there in the first place.
I would NOT do this -- you will rip the blade off the unibody of the car before the blade bends, which is made of thick aluminum. It's only held onto the car with a couple of bolts on each side.
