993 Forum 1995-1998
Need Help - Clutch Pedal Issue
Old Feb 7, 2011 | 04:50 PM
Vorsicht's Avatar
Vorsicht
Default Need Help - Clutch Pedal Issue
Just put in a new clutch along with a new slave cyl & hose. The clutch pedal goes to the floor (not all the way, but almost) and stays there. On search this seems to be a bleeding issue.
I bled the slave cyl once right after connecting the hose and now twice more with everything back together (each time about pint and a half of brake fluid). No Joy.
Any suggestions? Bleed again? Replace master cyl??
Old Feb 7, 2011 | 05:17 PM
JM993's Avatar
JM993
I've experienced this too and the solution will (hopefully) be easier than you think. Simply cycle the clutch pedal over and over (in the beginning, you may need to reach down and pull it up with your hand). You will hopefully find that after doing this for a while the clutch pedal will return normally.
Cheers,
Joe
Old Feb 7, 2011 | 09:43 PM
Vorsicht's Avatar
Vorsicht
Default Great Trick
Joe, Three cheers to you! That did the trick.
I did about 200 cycles by hand and a few more by foot. Now, better than ever!
Thanks!
Old Feb 8, 2011 | 12:00 AM
JM993's Avatar
JM993
Old Feb 8, 2011 | 01:43 AM
goofballdeluxe's Avatar
goofballdeluxe
Cheers,
Joe
Do you do this with the engine off or on, or does that matter?
Old Feb 8, 2011 | 02:12 AM
race911's Avatar
race911
Off. Engine running or not really wouldn't matter as ultimately you're just pressing the release fork.
No real explanation why these this happens sometimes to these things, but it sure freaked me out on the first G50 car I did a clutch on ~20 years ago.
Old Feb 8, 2011 | 02:15 AM
JM993's Avatar
JM993
The engine doesn't need to be running in my experience - at least on the N/A cars without power assisted clutches. I don't have experience with hydraulic power assisted clutches (like those on the turbo), but I'd guess they should be the same.
Cheers,
Joe
