Rear spoiler won't activate - help please
Hi, I've done a search on the rear spoiler and found nearly 500 posts but unfortunately none of them covered my problem.
The rear spoiler will not activate either at speed or manually by using the rocker switch. When it does work it's a little noisy which I don't mind as it lets me know it's working.
I've removed the plastic cover from the mechanism and all looks OK, nothing loose.
Where do I start, is there a fuse as well as the relay in the footwell?
