second engine harness?
OK, so I am installing the new engine harness and laying out wires. I seem to have gone from "wow, there sure are a lot of wires" to saying " I don't think there are enough wires" Is there a separate harness that will hook up to the idle speed adjuster and the change over valves on the V-ram?
Thanks,
Emerald
Thanks,
Emerald
They are located here on my car...
Hope this helps.
BTW, reasonable grouping depending on the distance. I get mine in a quarter at 33 feet.
ISV, MAF, knock sensor, intake temp harness part of cabin harness upper right corner of engine cabin. Stays on car when you remove engine.
