993 Forum 1995-1998
OBD II code
Old Feb 3, 2011 | 03:23 PM
M Fig's Avatar
M Fig
Default OBD II code
Just went to autozone to check/reset my cel. Anyone know what p1411 is?
Old Feb 3, 2011 | 03:31 PM
vincer77's Avatar
vincer77
SAI cyl 4 to 6
Ouch.
Old Feb 3, 2011 | 03:57 PM
M Fig's Avatar
M Fig
thanks...I think?
Oh well, I guess the good news is that I don't have to get my plates renewed for a year and a half. I guess I need to find a place that cleans out the ports. I'll do a search but is that the common consensus now...to get the ports cleaned?
thanks
Old Feb 3, 2011 | 04:03 PM
cabrio993's Avatar
cabrio993
I wouldn't freak out or jump into cleaning the ports yet. Clear the CEL. Use some Techron or any strong Fuel Injector cleaner for the next 3 or so fuel ups, and drive the car like you stole it. Rev it high and hard to get some of the carbon deposits off. See if the CEL comes back, or not. Sometimes, it is just the SAI valve that may need replacing. GL.
Old Feb 3, 2011 | 04:05 PM
Kika's Avatar
Kika
Originally Posted by M Fig
thanks...I think?
thanks
first search for SAI bass string, I would try that first and try to roto-rooter the block. It may also be the check valve or a bad O2 sensor will give you a CEL.
general consensus is probably to
1. clean check valve
2. check 02 sensors
3. use bass guitar strings if ports are clogged.
last resort is top end valve job.
Old Feb 4, 2011 | 09:47 AM
DanL993's Avatar
DanL993
button queen
There's also a nice post about a guy using the cable from a bicycle hand brake--seemed to do the trick IIRC.
Old Feb 4, 2011 | 10:21 AM
g_murray's Avatar
g_murray
Just curious -- how many miles on the car and if the check valve has ever been changed.
G.
Old Feb 4, 2011 | 11:44 AM
Slow Guy's Avatar
Slow Guy
Veteran: Navy
Wouldn't bother trying to clean the check valve, just replace it. If you don't crunch it up getting it out there isn't much you can do to clean it.
I would do the roto-router job on it anyway instead of waiting for the ports to get clogged up and hardened further. I did mine in Dec. after I put the engine back in from the DMF/clutch replacement.
Old Feb 4, 2011 | 03:05 PM
Deadeye's Avatar
Deadeye
Does MO require emissions testing? if no, disregard following steps and just get a cheap code reader that will let you clear the code yourself. As stated above and in this order, 1. clear code and see if it comes back. 2. find out if the check valve has been replaced. If not (or if you can't verify) change it asap. If the light comes back after doing 1 & 2 get the ports roto rootered out before they become blocked beyond clearing short of removing the heads.
