993 Forum 1995-1998
Do RS/EVO uprights = faster steering ratio?
Old 01-20-2011, 11:59 AM
sonny1
sonny1's Avatar
Originally Posted by Bill Verburg
here are the correct turns lock to lock(this is all documented in factory lit.)
Both 964 and 993 have power assisted steering, however 964RSA and RS manual racks are available(more turns = slower
911 is ~3 turns lock to lock, non assisted
964 is ~2.81 turns lock to lock, assisted
993 & 993GT2EVO is ~2.47 turns lock to lock assisted
993RS 2.73 assisted
964 manual ~2.6
Actual steering ratios, again factory specs, higher# = slower
964 18.48 slowest
993RS 18.25
993 16.48 fastest
Yes, great info., but why they put a slower ratio in the RS??don't follow the logic here.,cheers.
Old 01-20-2011, 01:34 PM
Bill Verburg
Bill Verburg's Avatar
You will have to ask a factory rep. i'm not a mind reader
Old 01-20-2011, 01:55 PM
Akerlie
Akerlie's Avatar
I rest my case
Old 01-20-2011, 03:15 PM
MarinS4
MarinS4's Avatar
To compensate for the quicker response of the RS/EVO uprights?
Old 01-20-2011, 04:31 PM
Bill Verburg
it's a free country and you can believe whatever you want
Old 01-20-2011, 04:53 PM
vincer77
vincer77's Avatar
You are right in a sense, look at the following to get a sense of what happens during supension travel
Wow Bill, you have a diagram for everything it seems.
Old 01-20-2011, 05:09 PM
MarinS4
MarinS4's Avatar
I was just teasing Bill. I do believe they are the same at this point when taking that tie rod angle into consideration.
Old 01-20-2011, 05:33 PM
Bill Verburg
They are not the same
They are equivalent at the design ride height for each different part
Old 10-13-2020, 04:43 PM
Endoman
Endoman's Avatar
Originally Posted by cabrio993
It is just an optical illusion due to the angle of the lower arm on the standard upright vs the EVO upright.
As you can see in the picture, the distance between the center of the holes on each one of the uprights is exactly the same. One curves left to right, the other right to left, to accommodate for lower arm while retaining the same distance to the pivot point. This causes the optical illusion that you are probably seeing.
Sorry this is incorrect. On the std. upright the trackrod end is fitted from above, the RS from below thus the effective steering arm length is longer on the std upright.
Quick Reply: Do RS/EVO uprights = faster steering ratio?
