Oil Temp Q for owners of both a 911 and 993 owners (cross post)
Addicted Specialist
On your 993, you know how the oil temp needle drops when the thermostat opens ...how you can see the needle actually dropping?
Why does my SC not do that? That oil temp guage moves along its path as the oil heats/cool, but no clear indication from the needle that the thermostat has opened from its closed (cold engine) position.
My SC btw is in great shape, and has been so now for many years, and no probs whatsoever. I am simply curious about this and have been so for years. Anyone got the answer?
Edward
Edward
Ed, when you drive, how long do you drive it? How do you know it is not stuck open?
I see the most dramatic temp needle drop on cool driving days in the Spring and Fall. Less so on hot summer days. No engine tray here.
I'm thinking stuck (open) thermo....or not getting it hot enough to open, and drop heat.
Edward
Edward
on a 911 w/ a 3.6 t'p and only a front cooling setup will see the same sort of thing as a stock 964 up, small down, up, plateau. The small down is the long run of cool oil in the front lines mixing w/ and cooling the main supply temporarily. This isn't as noticeable in a 911 because of the inner engine mounted loop of cooling.
Addicted Specialist
OK, now that makes sense! Thanks, Bill!
I never accounted for the difference in the engine-mounted oil cooler. How you describe the mov't of the needles is exactly how mine behave in both cars: 993 has that small drop down, then a plateau (more or less, of course); and the SC has no such drop but does behave exactly as you wrote. Now that you explain it, and the absence of that engine cooler in the 993, it makes perfect sense!
Still, I wonder if the T-stat on the 911s opens more gradually than the 964/993 T-stats ...do the latter units go "full open" from a fully closed position? I know in motorcycle oil coolers of years old (when I was deep into that decades ago), a simple bi-metallic strip was all that opened/closed the loop, so the addition of the finned cooling area was gradual. Dunno about how the 964/993 T-stat works, though. Any light to shed here?
FWIW to all, the SC is my track car, but does get streeted occasionally (to keep her exercised), so I know she gets plenty of heat, and the needle does rise in a timely manner on warmup, so I know it is not simply stuck open.
Edward
Edward
sorry, wrong thread
Wrong thread
