996 seats in my 993 C4S wiring.
Just got a pair of 996 full-power, no heat seats for my 1996 C4S.
From the pic below I see three motors: A, B & C. With a plastic cable which has a worm gear within it (D). All three motors go to the black box: E.
However, two connectors are empty at F & G.
Anyone know what operations the F & G connectors function ? Each connector at F & G has 5 electrical pins in them.
Each of the three motors (A, B & C) have Red, White, Black and Brown wires going to each motor: H.
Also, there are four wires at I, which I assume are the seat belt wires ?
My current 993 C4S seats are driver full power, no heat and partial-power for the passenger seat. I have read on RL re the mechanical changes I should make, the pins and raised metal piece that need flattening, but the electrical set up has me confused.
Hopefully this is NOT a memory seat system ?
Thanks, Patrick
Thanks, Patrick
Agent Orange
Wow, those seats look seriously medieval!
When I put my seats in, there was a harness with thicker red and brown wires and a bunch of thinner ones. The red and brown are the 2 wires that you need. If your seats are indeed memory that complicates things... My seats have only electric back rest adjustment, everything else is manual.
Hope this helps.
Hope this helps.
I have factory lipstick red interior that was an option for the 993 C4S. So these seats look at home. I found the 4 wire connectors for each of the three 12v motors. I also found each of the seat switch cables that have the thin wires. I hope to bypass the computer by hooking all the motor wires to each other via each respective seat switch and just remove the computer box altogether.
