993 Forum 1995-1998
Jic 993 users, what spring rate you using ?Hows it feel
Old Nov 27, 2010 | 12:18 AM
moots's Avatar
moots
Default Jic 993 users, what spring rate you using ?Hows it feel
Hi
Ok obsessing about suspension right now, I am installing JIC cross coilovers next week and just putting things together. I am trying to decide between 7/10 springs and 8/11 The cars not a daily driver but will mostly be used on the roads however I am hoping to get more and more track day in, so I want something that can grow with me as my skill levels increase. My question is what spring rates are you guys are using and how do you like the ride, does it work etc. what are your recommendations.
Thanks you your help
Old Nov 27, 2010 | 02:19 AM
993_Pilot's Avatar
993_Pilot
I bought mine used with 8/11, but I haven't installed them yet and can't comment. I will watching the replies with interest. What sways are you going with?
Old Nov 27, 2010 | 08:37 AM
IXLR8's Avatar
IXLR8
Originally Posted by moots
My question is what spring rates are you guys using...
Wouldn't it be great if manufacturers of both OEM and aftermarket springs would publish that data so that comparisons could be made. I asked that question some time ago.
Old Nov 27, 2010 | 10:33 AM
gjones1735's Avatar
gjones1735
Hi All,
I just finished re-installing my JIC's Tuesday. I own a 1995 993 coupe and use the standard 8 / 11 springs ( the new style gray ones ). The car came with the JIC coilovers and I just had them re-built using the new pistons and seals to bring them up to date. Like you, I use the car as a daily driver as well as one or two multi-day track events a year. The car also has a stiff TRG anti-roll bar and tower strut. I vary the ride height between ROW and ROW Sport depending on what I'm doing with the car. Likewise, I vary the JIC dampers from soft to medium hard depending on if I'm around town or on the track.
I would describe the ride around town as firm but very precise. You know that you are in a perfromance car but it's not harsh like a true track car. Since I had them re-built I've noticed that they are smoother. Their performance on the track is outstanding. I do run them in combination with a lowered car and with a heavy anti-roll bar and tower strut so it's tough for me to say that track performance is due only to the JIC's. Now's the time to do the other stuff if you want to as you have to remove and re-install the anti-roll bar anyway and the tower strut attaches to the top of the front camber plates.
Important! Although I did all this work myself; the final set-up and alignment really needs to be done in a dedicated Porsche shop with the proper equipment and by someone who really understands Porsche 911 racing suspensions. I installed everything and then drove it to Lufteknic in Richmond, VA to have the shop owner, Robert, do the final set-up and alignment work himself.
Have fun,
George Jones
Williamsburg, VA
Old Nov 27, 2010 | 11:05 AM
Bill Verburg's Avatar
Bill Verburg
25 Year Member
Hi
When I first installed JIC on my car I used 7/10 because LRP(the main venue) was a bumpy nightmare for stiffly sprung cars, It was great for that and for street use, moving on a few years, LRP was repaved and not so much street use anymore so 8/12 went on, I didn't like the body roll associated w/ 7/10. This is great for smooth track use and occasional street use. I use 12 in back rather than 11 to reduce understeer.
Old Nov 27, 2010 | 03:05 PM
jaholmes's Avatar
jaholmes
I have 10k front and 14k rear and surprisingly it's not that bad. This was supposed to be a track setup but haven't seen much track use. I think 7/10 is their soft for street use and I would go for this combo instead of a PSS10 setup.
Old Nov 27, 2010 | 06:14 PM
moots's Avatar
moots
Wow 10-14 that sounds serious, what sway bars are you using?
