Lowering 993 from US height to euro/ rs whats needed?
I am planning to lower my car from us height to probably rs height, here is my question I have coilover jic cross ready to go what else do I need? Rs droplinks? Do I need the evo hub (thing?) for the front? Anything else I am forgetting? Finally I have a set of adjustable h&r sway bars, should I use them or stick to stock. The car will spend 80% of it's life on the street. Thanks for any advice it's great to have this resource, your doing us newbies a great service.
Anthony
Anthony
Since you say this will still be an 80% street car, I assume you are lowering it more for looks than handling characteristics. If so, then all you need is the rear drop links - I used Tarett but there are others. You do not need the RS/Evo/GT2 uprights, but work with your mechanic to make sure your geometry does not get too out of whack. I am RS minus ride height and use the stock sways, so you do not have to out the H&R's on, but feel free if you want. That said, the H&R's will stiffen the suspension that much more which you may not like since this is a primarily street car - you might start by not changing them to see how you like the ride.
The JIC's are great and you are going to like the feel versus stock. Good luck and post pictures.
The RS rear bar is adjustable and fits under the lower control arms . Without the curved links you will not be able to adjust the rear bar to the stiffer position. I don't know if your HR bars are intended to be mounted below like RS or above like a standard bar.
993RS hubs are nice for cars lowered to or below RS spec.
RS adjustable sways run below the transverse suspension arms and to get full adjustment range from the rear holes you do need the curved RS droplinks in back. In front you will want stronger droplinks so either RS or Tarret there
There are lots of pics and discussion in the archives
