993 Forum 1995-1998
For S's and Giggles - Any way to raise 993 rev range?
Old 10-30-2010, 03:57 PM
race911
race911's Avatar
What's the realistic life expectancy of the ultra-modified large bore/stroke air cooleds? Quite happy with my meager ~315HP 3.8L that stays within the factory rev range. When I want to go rev happy, the 10.5K of the Hayabusa in the Radical is satisfactory.
Old 10-30-2010, 04:24 PM
bobesser
bobesser's Avatar
Originally Posted by Steve Weiner-Rennsport Systems
Stock heads, intake and exhaust systems pretty much restrict HP to about 7K. RS cams simply bolster the existing RPM range,... . $25K is acccurte.
With an ITB or slide-valve system, the right cams, better heads, lighter pistons, all the above mods (plus the oiling mods), and an appropriate exhaust setup, you're good to 8200+. All that takes is a bunch of $$$$$,.... I know of one 3.9 litre race engine making 460BHP+, but that was quite expensive to do.
It may not make peak power over 7k, but, as long as it didn't drop off too much, it would still be usable. It would be nice to have another 1000 RPMs available in an autocross.
So, hardware, we are looking at:
Rods/bearings - $1500
Pistons and cylinders - JE and Nickies - $4000
reworked heads with RS valves and high RPM springs, retainers, etc.- ??? $4000 (guess - please correct)
Improved Oiling - No idea what you would do here - would you need to crack the block?
Bob
Old 10-30-2010, 04:40 PM
race911
race911's Avatar
Uh, yeah. GT3 oil pump, 964 or GT3 crank. Among other nuances. Bolting one of these things together outside of plain ol' stock is more than the sum of a bunch of parts.
Look, Kim spent $30K+ with Steve in '03 to take the stock tired ~120K '95 engine into what it is now. Along the way, it dumped a crank, so a 964 one went in later. This is a 7K RPM engine, at best.
I have no idea how serious you take autocross. For the kind of money that's being discussed to properly and comprehensively take these engines into the 99.9th percentile, a 911 is one of the last places I'd look for ultimate speed.
Old 10-30-2010, 07:15 PM
bobesser
bobesser's Avatar
Definitely not that serious. But I am curious to know what it takes and it is quite fun to imagine.
Bob
Old 11-01-2010, 11:15 AM
cohare
cohare's Avatar
yeah I would rather have a fully built 993 motor than retro fitting the GT3 water pumper. I agree with bob, another 1k rpm would be great in atuox and on the track.. I'll probably end up going the re-geared tranny route to improve accelaration but, would love to have the combo.
Old 11-01-2010, 12:22 PM
bobesser
bobesser's Avatar
(I went supercharger)
Old 11-01-2010, 12:33 PM
cohare
cohare's Avatar
Bob - I know you did, which is awesome. for some reason I want to stay naturally aspirated, I dont feel like at my skill level I need much more power (probably dont need any) the rev question was just because I love a high revving NA motor.
I think if I ever go with a regear it will help with autox and on the track it shouldnt hurt either!
Old 11-01-2010, 01:10 PM
bobesser
bobesser's Avatar
The /30 and /31 gear sets seem to have a higher 1st and 2nd, which is good. seems to me that for autox, you want a pretty tall 2nd.
Bob
Old 11-01-2010, 01:43 PM
race911
race911's Avatar
Maybe, maybe not. Gearing in the yellow car is horrible for Laguna, so much so that with the sound restrictions there's no point in taking the car there.
Old 11-01-2010, 05:47 PM
Bill Verburg
Bill Verburg's Avatar
Ken, your gearing is odd anyway(unless you redid it from when Kim owned it - yours is Zonker above
compare that to the /30 Cup, /32 RS/CS or /31 RS street
The 2 I like the best are the /30 Cup and the regear that Chris Cervelli did for Leland
the /31 and /32 are going to be better for the guys that also use them on the street, though I think mine /30 is fine there too, the others have the higher 6 for fuel
economy cruise
Old 11-01-2010, 06:34 PM
GTgears
GTgears's Avatar
That just shows how little differences in ratios can make a big difference on track. Zonker actually uses the same 4th and 5th gear that the factory recommends as the optimum stack for Laguna Seca, but 3rd is shorter and 6th is taller. Porsche suggests the following:
1st 3.154
2nd 2.000
3rd 1.571
4th 1.307
5th 1.094
6th 0.941
Old 11-01-2010, 06:43 PM
Bill Verburg
Originally Posted by GTgears
That just shows how little differences in ratios can make a big difference on track. ....
I think that's the hardest thing for most people to grasp
Old 11-01-2010, 07:03 PM
race911
race911's Avatar
1st 3.154
2nd 2.000
3rd 1.571
4th 1.307
5th 1.094
6th 0.941
Odd. (And yes all is the same as when Steve built the car.) You're hitting MAYBE 120 at Laguna. In any case, 2nd and 3rd, ESPECIALLY 3rd, are why it sucks at Laguna. But it's all just fine for Thunderhill and Sears.
Old 11-01-2010, 07:08 PM
race911
race911's Avatar
And I just noticed on the chart that the universal tire OD is 24.6". I've been generally running a 275/35-18 or 275/40-17 RA1 during my ownership. Subtle difference.
Old 11-01-2010, 07:20 PM
GTgears
GTgears's Avatar
The other thing is the original topic of this thread, the redline. I posted GT3 suggested ratios, which obviously has a higher redline than all but the most crazy 993 based air cooled motors. So those ratios will come up too short for the 993. I'm just guessing without charting it, but something like a 0.866 6th gear is probably better for a 993 car, as would be a 1.895 2nd and maybe a 1.521 3rd. Basically something closer to the Chris Cervelli ratios that Bill said he likes...
Quick Reply: For S's and Giggles - Any way to raise 993 rev range?
