How to replace the center reflector?
I have removed the 3 long bolts and the four screws you see in the picture. I have also loosened the tailights. There seems to be 3 or 4 plastic clips along the bottom that secures to the car. However, I still can't get the broken reflector to remove from the car. Is there something else holding it in? I am scared to yank it hard.
Thanks, Brandon
Thanks, Brandon
I cant see from your pic if you removed the 3 allen screws (Red circle), if not remove them. Than lift the rear (toward engine) part of the reflector. There are 3 pins under the reflector (you cant see them, black arrows) which secure the reflector and lay in kind of oval holes. lift the reflector and pull it at the same time and it will come out.
shahrams, thanks man! I didn't see those allen screws as they are black like the rest of the piece. It is now removed. I will be back shortly if I can't get the new one installed.
