Deck Lid "Carrera" Badge Replacement
Oct 21, 2010 | 06:47 PM
Hello - Thanks a bunch for all the informative posts. They have been a huge help learning about my new "Mistress in the Garage". I'm wondering if anyone has had this experience. My deck lid plastic badge has partially broken off. I have an OEM replacement and am trying to figure a way to get the original cement-like glue off the deck lid. Man, this stuff is like granular concrete. I've tried goo-gone which didn't do a thing. I'm almost tempted to stick the new one over the old adhesive but really don't like that idea. Any suggestions?
Thank you very much, and GREAT FORUM!
Regards,
Oct 21, 2010 | 06:56 PM
Heat it up with a hair dryer and keep using the Goo Gone. It will come off eventually.
Oct 21, 2010 | 08:03 PM
To remove the rest of the badge, continue using the hair dryer to soften the glue. Then use dental floss to cut through it.
Oct 22, 2010 | 12:31 AM
Thank you - Hair dryer worked good, new badge installed. Regards,
Oct 22, 2010 | 09:11 AM
On this subject, does anyone have a "fool proof" way of exactly centering that badge with you replace it?
Is there a template, or do you just measure with a micrometer and mark it with a grease pencil??
Oct 22, 2010 | 09:37 AM
Super Moderator Needs More CowbellLifetime Rennlist Member
Try using blue or green painter's tape to establish 'guide lines' at the bottom and side.
That should help a bit.
Oct 22, 2010 | 09:46 AM
Oct 22, 2010 | 10:28 AM
+1
Oct 22, 2010 | 10:35 AM
Yes, badgeless is the way forward
Oct 22, 2010 | 11:09 AM
Badges ?
We don't need no stinkin' Badges!
Kidding aside, I have had mine off since 30K miles. Available for anyone that needs a replacement.
FS - $20 shipped.
You'd just need to clean up and reapply trim adhesive.
Best,
Matt
Oct 22, 2010 | 12:19 PM
I wanted to go badgeless, problem is there is a "ghost" mark in the paint so for me it was not an option.
Oct 22, 2010 | 12:41 PM
Quote:
Originally Posted by
Renaud Bizet
A good detailer can correct that paint for you if that is a concern.
Personally, I like the badge, then again I like the basket handle.
Oct 22, 2010 | 01:35 PM
makes sense. perfect match...
Oct 22, 2010 | 04:15 PM
I thought I was the only one.
Oct 22, 2010 | 05:17 PM
2Many Cars
There is a growing underground.
