Cab top working like new again
Well, I'm happy to say that I 'discovered' the guy that Porsche Cars North America trained on the west coast to be the trainer for all the other dealership techs that were selected to learn to repair the 993 power top and he was right under my nose, at S-Car-Go in San Rafael http://scargoracing.ypguides.net/ where I had the PSS10 suspension done on my coupe. His name is Pat Sexton and he's a Porsche certified Master Mechanic that spent most of his career as the Lead Service Tech at Sonnen Porsche in Marin. Nice guy, pure craftsman.
So, when I described my 'problem' to Pat, he immediately said either one or both of my motors were loose and/or disconnected causing the 'gap' in tension during operation. He also said that when the top system is adjusted and timed properly that it should work perfectly for years and years with a minimum of maintenance and that most owners never read their operation manuals or the following TSB's that Porsche released on the tops and their proper care and operation which has caused many of the problems. He also said that he had to study and work on several top systems to get to the point where he could get them aligned/adjusted and most importantly, all the switches and motors 'timed' together properly so the tops worked correctly but after they are adjusted properly they should work flawlessly with a minimum of maintenance, for years.
As soon as he inspected the system, it was apparent that someone had tried to 'fix' the top in the past and had disconnected the drivers side motor as a result, leaving the passenger side to do all the work. It was never apparant why this was done because everything seemed intact. Luckily, it hadn't been that way long so no damage to the carriage mounting points or gear transmissions had been done, however, both drive cables were worn (they constrict over time, not stretch ...big surprise) and the elastic tension straps on both sides had been damaged because the original factory installation of the straps causes them to get caught between the aligning pins on the frame and the slot the pins nest in, which is documented in a TSB.
Pat also said that many cabriolets top assemblies are bent/damaged because the rear bulkhead panels were welded in out of tolerance at the factory and cause the top assembly to compress as it folds down and there's also a TSB that covers that repair. The panel actually has to be "reformed" slightly to allow the top assembly proper clearance. Fortunately, my car, being a '98 and late production it didn't have that problem, but it seems like Porsche should repair cars that do. That might be part of recall number A502 that replaced the front locking motors and did a complete 'service' on the top and it's components.
So, after everything was taken apart, cleaned, lubed, checked for damage/function, reassembled with new cables, re-installed, adjusted and all the motors and sensors re-timed to work flawlessly together in synchronized harmony (which he said was 'The Black Magic' that is needed to get the top to align and work perfectly without causing damage to the assembly or needing any manual assistance) I'm happy to report that my top opens and closes perfectly and quietly, like a swiss watch, just like it was designed to do.
Total time: 3 hours at the hands of a Master. Total cost, parts, labor and tax: $1033.67. To be honest, that seems reasonable to me considering the result. The parts weren't cheap at $270/each cable and $80/each for the two straps, and, interestingly, it seems they are not pictured in the PET. Luckily, S-Car-Go had the NOS straps on the shelf from years ago and they were able to get cables delivered in an hour.
I may pay S Car Go a visit,
Thanks,
D.
Thanks,
D.
