Strong Engine Smell
Strong Engine Smell
Hi guys,
Just wanted to know whether anybody else has experienced this... after easy driving i got a very strong engine smell. the oil temp was sitting around the middle of the gauge when i was driving - which is too high - if possibly this has anything to do with it. i parked my car in the garage and the fan came on and distributed the smell around the garage. any idea what would be the cause? Not sure how to describe the smell other than a strong dry sharp engine odour, which went away after about an hour - i guess once the car cooled down.
regards
alan
regards
alan
Can you provide more details of the odor? If it's an oil smell, that's somewhat common with these air cooled engines. As far as the oil temp guage pointing at the 9:00 position, I don't think that is uncommon either.
Thanks for the comments - its quite a broad question / problem. Guess was just worried with the smell / temp that i was not frying the engine or something. What i may do is take off the engine tray and get the engine cleaned and see if that makes a difference.
At what outside air temperature and driving style?
Mine is at the first mark at about 20 degrees C OAT and just cruising along
yeah about the same
yeah about the same
Engine odors like hot oil, hot rubber and exhaust are all normal to a certain extent. This makes it hard to say if what you are smelling is abnormal. Is this a new smell?
What I had in mind was what I randomly experienced, once: A/C belt ended up, somehow, losing a smidgen of tension and was rubbing. The belt would be visibly frayed and, at least in my case, the majority of the shavings got caught right behind the carrier.
Easiest way to check this is to "see" if the smell gets worse at high RPM. Test it in a lower gear or out of gear. You'll outrun the smell at speed.
