10+ HP for $349?
10+ HP for $349?
I stumbled across this site that claims HP gains of 10-12 for our cars and was curious if anyone here is familiar with this or tried it out.
http://www.evoms.com/marketplace/vie...-28596EBE76FC}
I'm not considering it for my car, just curious as to whether or not it works as advertised.
Still plays with cars.
You can get a small power gain by drilling a half dozen one inch holes in the airbox cover. This was tested by Bruce Anderson, confirmed at Tech Tactics and published in Panorama. He also dyno tested the engine with NO AIR FILTER at all and got zero gain. The 993 air intake was restricted due to noise regulations. Adding holes does improve sound and gets a few more HP at high RPM. The K&N etc. are pure nonsense.
You see countless companies making claims, especially those aftermarket exhaust manufacturers (same goes for those battery charger manufacturers .
I subscribe to a quality motorcycle magazine who periodically picks a bike and tests about 10 aftermarket exhaust systems and compares the power and torque curves to stock curves. You know what...none of the aftermarket exhausts are of any benefit. They have a spike HP gain up at a kazillion RPM hardly worth talking about, but lookie down below where we usually use our engines...the same or usually less HP and torque. What a waste of money!
I've never had a high opinion of them simply because I can't verify their performance after X washings.
Looked into K&N many years ago for my motorcycles. The K&N simply flows more air by not filtering down to a smaller micron size than the factory elements, plain and simple. You WILL get more dirt particles going in to your motor. One of the board members on the mc forum I frequented was responsible for maintenance on a large fleet of earth moving equipment with rigid service requirements for the motors. They kept very accurate data on engine life and service costs (air filters, oil filters etc). Their conclusion was that the K&N reduced engine service life. They returned to the paper element filters.
If you value longevity of your motor, do NOT put in a K&N.
It does not matter how much potential airflow an air filter has, what matters is if the existing air filter causes a flow restriction in the induction system. Porsche air filter systems are pretty efficient - by design. I've never seen any power gains with K&N or other aftermarket filters on Porsches. As noted complete removal of the air filter often shows zero improvement in power.
Typically manufacturers use results based on some horrible OE system as a basis for their performance comparisons even though they may not apply to most applications.
